sli 260 or crossfire 4780?
the 192 sp gtx 260 is closer in performance to the 4870 512, and the 216sp gtx 260 is closer to performance to the 4870 1gb. of the two cards you linked, the ati crossfire setup is faster.
depends what kinda games you play, if you're a crysis whore then definately get the gtx260's.... theres a great deal on them in the hotdeals section right now too.
personally i like ati cards better though.
im presuming you're deciding between the cards to use on an x58..... if you decide to go SLI then dont do it on an nvidia chipset.
I'd go for Evga GTX 260 SLi and manually OC it to 660 or the best you can get on the core.
They officially support end user overclocking, HSF replacement and have a lifetime warranty. Their support is also awesome.
Grab their Precision tool. It will OC both cards.
http://downloads.guru3d.com/EVGA-Precision-1.3.3-download-2112.html
If you play 1920x with AA you do not want 512Mb cards. They may give good looking FPS on paper and feeling like trash in actual play. [H]ard has pointed this out in a few reviews describing unacceptable stutter with said cards in the situation I describe in some demanding titles. Also nVidia GPU PhysX is only going to become more and more meaningful.
I don't really play crysis. Red alert 3, call of duty are more my kind of games. I personally want the 260's just because I like evga, unbeatable customer service and warranties. However, I had a x800xt for a while a few years ago and it was pretty awesome. Performance wise, I'm sure these cards all math up pretty closely but if I'm wrong could someone link articles comparing these setups, if there are any? Thanks
http://enthusiast.hardocp.com/article.html?art=MTU2OSw0LCxoZW50aHVzaWFzdA==
call of duty scales brilliantly with the 4870's.... if you're not into crypiss then i would definately go for the 4870's . the deal going on in the hotdeals section is pretty tempting though with the gtx260's:eek:
if you have to buy a nvidia mobo to go 260 sli, meaning you dont have an x58 then go with 4870's, nvidia mobos SUCK
as said above you can save money by going with a 4870X2
having said that if your going to an i7 board then SLI is a good option, otherwise you should be only looking at crossfire. Nvidia boards are not famous for being good.
Outside of that it six in one hand half dozen on the other.
I plan on coupling these video cards with a i7 920 and most likely the asus p6t x58 or some other x58 chipset motherboard. It seems that most people here think that sli over crossfire would be good on that?
well the 260's and 4870's are close performance wise (apart from crypiss)
but the 260's can be had for under 200 bux each which makes them a good choice for your wallet.
well as ATI is dropping the price its back to being a tossup. some games will scale better in crossfire others in SLI. For myself I would look at ATI for the CFAA. outside of that look at which games you think your going to play and go from there.
On thing to consider is that if your wanting more performance then SLI GTX260 or crossfire 4870/4870X2 then look at the GTX280 SLI, scaling past two GPU generally sucks though the i7 platform is suppose to do better.
