Sleeving...
lamb110
How hard is it? i have a few links to some guides, but i've never done something like this before. I want to replace all the connectors with some UV blue ones, and sleeve the wires so it looks good too. I have an Antec TruePower 2.0 550W if it makes a differnce. Also could you link me to some good kits? I will also need to sleeve a few fans, actually more like 12 total, so is it better to buy several sleeving kits?
Sorry if i sound like a newb, but you have to learn some how :)
I have a ton of time on my hands and nothing to do lol
you'll need a molex remover for sure. for sleeving get them at www.voyeurmods.com for kits i suggest UV kits and the molex remover www.xoxide.com Try www.frozencpu.com as well. I suggest you buy individual sleeves because you can get different colors but if blue is all your looking for purchasing a few kits will be sufficient.
