Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Friend of mine would like to do this. Anyone know how to remove the caps so he can sleeve the cables? If not, any secrets to doing it an alternative way?
Most* prewired Serial ATA power connectors are factory assembled with the wiring. They use a non-reusable connector design and should be clipped off if you plan to replace them. If it's obvious that they're not going to come apart cleanly, then save yourself the trouble and buy some IDC versions. IDC, or Insulation Displacement Connectors, bite into the wire insulation for an easy, effective connection. You can buy them at many online vendors. Here is one example:
