sleeving SATA data cables
DisrupTer911
Some guys I see sleeve their SATA data cables but I'm leary about dismantling the connectors to get teh sleeve and heatshrink over them...
Are you guys buying or just somehow stretching the materials?
I don't believe anyone takes apart SATA cables. Just use larger heatshrink. Sleeving stretches of course, so you don't have to worry about it as much.
^yea that guy is awesome, even draws you your very own personnel picture.
shipping is fast too.
Nobody takes the cable apart. As, was said, you slip the sleeve and heat shrink over the connector. Using a pair of scissors helps.
