Sleeving my psu
monk3y
I am resleeving my Corsair 520 but I have run into a little problem I bought a tool to remove the pins from the atx power connector but it is not working. I know I am doing it right because I tested it on another psu. Any suggestions?
for some reason none of those things worked, I may just cut off the ends and and just redo the connectors
That's the way I felt.. but once you master the technique, it becomes easy. They're just really hard to get out on your first few tries.
