I'm looking to get some sleeving to mainly do my fans, and minor wiring, as most is hidden behind the mobo tray any way. However, I have no idea what's the "better" sleeving kit to use, what size heat shrink tubing I need, and what tool kit I would need as well. I'm basing the product selection off of SVC.com.
Sleeving:
http://www.svc.com/flexokits.html - I'm looking at blue sleeving. Wasn't sure If I should go with the Logisys or the "UV reactive" one. Is any one better than the other on that page?
Heat Shrink - This is necessary when sleeving, correct? If so, would a blow dryer be sufficient, as I'm not fond of putting a lighter neat the cabling.
http://www.svc.com/heatshrink.html - Have NO idea what sizes to get for the normal 3 & 4-Pin Molex.
Tools:
http://www.svc.com/pmtk.html
Would that be he tool set that is needed to remove the molexes?
Any help is GREATLY appreciated.
Sleeving:
Tools:
