Sleeving an Antec NeoPower
Hexus0
Hey everyone, I'm going to sleeve my Antec NeoPower480w soon, and I was wondering before I buy a sleeving kit (and the molex pin extractor [if I need it]) will I be able to fit the sleeves over the back of the wires (not the molex but the part that connects to the PSU itself) so I wouldnt haven't to take off the molex? or would I be better off buying a molex pin extractor and doing it like that?
Like this part right here (yellow and black wire with the black thing on the end)
its really easier than it looks. with a pin extractor you could probably do a full psu in an hour.
just buy a sleeved NEOPOWER cable kit from performance-pcs.com. only around 10 bucks
made esp. for the neopower
I would suggest a pin extractor, as it saves your finger/reduces the risk of breaking wires. You might be able to get the sleeving over the connectors, but I would worry more about the heatshrink.
