Sleeve question
meinzorn
How do you sleeve sata power cable wires?
I can't seem to figure a way to get them off?
If I cut the wires.. Could I just splice them back together without any issues with the power supply?
You can remove the sata power connectors. How you do it depends on what type you have.
Here's about the best thread and how to in the internet in regards to sleeving...Nils from MDPC-X posts there all the time.
http://www.xtremesystems.org/forums/showthread.php?t=202639
Here's mine!
Looks nice.. I do think mine aren't removeable.. There is a cap on the middle ones but the end ones don't have it.
I might need to cut them off and replace them.. Any suggestions on a place to get sata power plugs than I can put on here..
Also, where do you buy your sleeving? And is it 1/8th inch? I was doing mine with various sized over the bundles of wires.. I like the look of the way you have it done better though.
