Alright, set up a little folder with a 750i board, e6600, 4gb, 8800GTS, 9800GT, 510w PC Power&Cooling.
Installed cuda 3.1 drivers, rebooted
Installed gpu3 client
Copied the fah folder in the programs x86 directory, named gpu0 and gpu1
Created shortcuts, made tags -local -gpu x (and on second gpu, -forcegpu nvidia_g80)
Checked nvidia control panel, the gpu1 (9800gt) is extended onto the second display (via svideo cable to monitor svideo input)
Now, gpu0 folds fine (8800GTS), but the 9800 just downloads a new core, goes to Working (0,0), then starts "Sleeping". Has anyone had this problem?
I have tried pointing it to the gpu0.exe (starting in its own appdata folder) and pointing it at gpu1.exe (starting in its own appdata folder). Both yield the same results.
Any help would be greatly appreciated! Thanks!
