Skyrim advice for playthrough on master?
PsichoDM
Folks,
what are your best recommendations for playing through Skyrim on master difficulty? I've been having quite a bit of trouble with my melee orc dual-wielder due to monsters such as dragons and ice wraiths basically two-shotting me. I could boost my smithing, pickpocketing and enchanting up to 100 real fast, but then I'd likely have all other monsters gain an extra 15 levels on me or break the game with overpowered gear, so I'm trying to keep every crafting skill under my one-handed melee skill points so that it's fair.
Suggestions? Anecdotes?
I play on master, and have found I hit F5 constantly, especially mid-battle if I am having a tough time. Land critical arrow on a Hagraven? Quicksave. Get a strike on a dragon? Quicksave. Etc.
Also, I use a companion at all times. As I specialize in 2h and Archery, I try to draw out single enemies when I can, let the companion engage the enemy head on, and concentrate arrow fire from afar. Then, if the companion goes down, I equip my battle axe and charge.
Also make sure to use full advantage of restoration magic and alchemy to make health potions.
Im not an expert by any means but I am playing master and have found it to be a rewarding, if sometimes frustrating, experience.
It depends on your build. Conjuration is OP for playing on Master, as the Atronarchs can tank for you.
Destruction is also pretty good once you get the Impact talent.
Sneak has been invaluable for my rogue-type character for pulling groups apart and such. I am trying to do it solo, but i'll grab a companion if there's an encounter that's too difficult.
I'm about to install the More Difficult Dragon Mod, so i'll see how that goes. They've still been too easy, but i'll bet that changes when i'm all alone.
F5 for sure. Every few steps that i know are good, and as you say even some times in tough fights too.
I find the only frustrating part is getting one-shot. I wish that were toned down a little and the AI improved, but alas--buffing dmg and health is easy where improving AI is not. This frustration, however, is amplified by the shitty UI which takes ages to navigate. So i'll spend 5 minutes in my inventory picking pots and gear and shit, leave the inventory and get one-shot... only to have to do it allll over again.
My advice? Lower the difficulty.
anything lower than master has required very little effort and basically feels like i'm cheesing my way through. I enjoy having to use everything at my disposal to beat encounters..
Play on normal max enchanting, max smithing , Light or heavy armor to 100 ... then u set it to master :p
All depends on how you are distributing your points. you want to level off your main combat skill to get it to 100 as soon as possible. If you are leveling a lot of other stuff also then you will have balance problems vs enemies where they dump all the points into one area.
