I was running the Acceleration Layer and then switched over to skyboost.
Skyboost definitely seems to help in some areas and is a whole lot better in cities when you let it do the 360 view... GPU usage is much less all over the place and fps is higher as well.
I didn't have any crashes with either, so I am betting those of you that are having problems with crashing has to do with some other mod not liking the Acceleration layer and/or Skyboost.
I have only changed a few threading options in the ini file, so some modded ini settings may affect it as well.
