- May 24, 2006
Yea congrats. This is gonna be SICK. Too bad they don't make a case for it, like those dual sided cubes...
There are cases for almost any motherboard but you have to look hard and they usually don't come cheap. I think one of my old cases should accommodate this board, or a few minor modifications will make it work. I measured it in the past for quad-socket boards and it does actually fit the smaller ones. There is a dual Xeon board in there now. Quad-socket systems are normally way too expensive for the PPD obtained, unless you can find a major discount on the components to build one on the cheap (relatively speaking).Yea congrats. This is gonna be SICK. Too bad they don't make a case for it, like those dual sided cubes...
Hope it helps.Tell him he only needs to plug in the 4-pin ATX cable if he's using quad-rank ECC RAM - so if he's not, then he'd be better off getting a 4pin-8pin adapter than a molex-8pin adapter for the second CPU pair.
Four GX2s would net you over 50,000 PPD with 353-pt WUs but less with other WUs. I have no idea what this quad-socket build could accomplish with -bigadv WUs. I know it will probably be higher but it will depend on the processor speed and I am unfamiliar with quad-core Opteron performance. I have a dual dual-core Opteron machine but that is older pre-Barcelona architecture.And fir value, as long as it competes with 4 GX2s then I've not lost anything, I'll only use less power too
There's greater risk running -bigadv clients than there is GPU clients with regards to WU stability, but like you mentioned less power consumption. So, trade offs in both types of clients. You purchased the components less than they normally can be acquired for, at least that's my understanding, but I really don't know what it will end up costing you in the end. In terms of longevity, it's hard to say which direction is superior, however there is always the expansion board option.
It is a great project no matter what the outcome. I've been interested in quad-sockets and higher since the 90s, when Intel released the quad socket-8 platform for Pentium Pro processors. Years later, I purchased a Hex-socket ALR Revolution 6X6 for cheap, which I still have in mothballs equipped with Overdrive processors. I have experience in socket counts above duals albeit with very obsolete hardware, and fully understand the excitement you are experiencing.
passively cooled chunks of copper,
or
Water cooled chunks of copper and better clock speeds if OC is possible.
I'm thinking the decision is obvious. but WC might be more expensive to setup. maybe we should make a community project and help him get some parts he wants.
pics....
WE WANT
I was thinking more in line with architecture longevity in regards to F@H performance, but I completely agree with you concerning wear and tear. GPUs are near if not the worst components when it comes to life expectancy, especially run 24/7.longevity wise this rig should be better then a gpu.. this is all server hardware.. its designed to take abuse 24/7 and last for ever.. hence why they are underclocked and undervolted processors compared to what we get in the consumer market(phenom II)
All my dual Xeon systems are OC'd, usually accomplished through software since BIOS functions cater to enterprise considerations above strict performance attainment.performance wise it should be close to what the xeon's get.. but i believe this setup also has the ability to overclock unlike the xeons dual socket setups..
There shouldn't be any but I haven't looked at these boards directly. My Tyans of the past including my Thunder K7 which is still folding, don't have any OC options at all. You would be lucky to have memory timing options in the BIOS.I played around in the bios lastnight but forgot to look for OC options
I don't think there are any if I remember right, but slash just did software OC I think
Agreed. Something should be available for it. There is a chance unlike pure server chipsets (Serverworks).Theres not OC options, but since its a nforce chipset, a software oc should be possible.
Assuming that it would be a simple affair, WC a quad-socket would be vastly more expensive. OEM server copper HSFs are considerably cheaper than consumer high performance aftermarket all-copper HSFs, at least for my Xeon Supermicro setups they are.Wonder if it'd be better to go with a crazy water cooling setup instead. Might be cheaper than getting massive chunks of copper.![]()
Yes, but I believe Vaulter is on a strict budget. This doesn't appear to be a proof of concept project but a dedicated folding machine, and believe there is a budget mindset involved in its construction, but I'll let Vaulter confirm this.passively cooled chunks of copper,
or
It will take longer to design and implement a complex WC setup for quad-sockets than it would be to acquire decent copper HSFs, which are essentially off the shelf parts and only a click away. These are not enthusiast type of setups that lend themselves easily to modding, and transformed to become the creative product of a fertile mind. Dual sockets are difficult enough but quad sockets are vastly more difficult, and expensive. It pays to be conservative and stick to the tried and true for this project, at least in the beginning. Once the system is up and running, then something more elaborate can be attempted.I'm thinking the decision is obvious. but WC might be more expensive to setup. maybe we should make a community project and help him get some parts he wants.
I totally agree with you Zero. Cost being a major factor here and the fact that there is security in numbers. If this system fails for whatever reasons, you lose all your production versus separate systems that are isolated from one another.Vaulter, it would probably be a better idea to buy a second mobo for the other four chips instead of getting the expansion board, since the board is actually about twice the cost of a new mobo. I suppose that's more of an issue for the future though. For now, a 16-core box should kick out a nice amount of PPD once you get it working.
well vaulter, i'll be joining you in the 16-core clubBought the arima 4-socket board. It's pretty much a free upgrade since my board will resell for more. I'll just need to play around with adapters to power the board.
Arima 40GCMG020-D400-100
8gb ddr2 ecc reg 667mhz
am2 heatsinks.
The older 8000 quad core are compatible, newer cpu maybe not since Arima was sold, etc.That is an awesome deal. I almost want to jump on that. What Opterons are compatible with that?
Do you have prospective PSUs in mind for this board? I also never seen 18-pin connectors and I'm skeptical if adapters exist for this configuration.The older 8000 quad core are compatible, newer cpu maybe not since Arima was sold, etc.
Please note the power connector is not standard (18-pin), and there's no manual/info anywhere.
I see. I was going to suggest a custom wiring job but know relatively little about that sort of thing. The most I have done in my experience was repairing damaged PSU board connectors, or modifying PSU wiring to run multiple units in tandem.no, I'll just hope i'll be able to see on the board which pin is transporting what, and do some wiring from molex. *fingers crossed
I think that will be a little more difficult than you are anticipating. If the 18-pin connector is keyed differently from the 24-pin ATX connector, you might have to jury-rig something, and as for figuring out the wire arrangement, the only way to do that would be to get it either from the motherboard manual (if they list it), or by taking a look at pictures of the actual male 18-pin connector and figuring out the pinout yourself.no, I'll just hope i'll be able to see on the board which pin is transporting what, and do some wiring from molex. *fingers crossed
Absolutely. You will need some diagram (hopefully detailed) before you attempt any kind of custom work, and even then it's not guaranteed to succeed. Fortunately it didn't cost you much.If the 18-pin connector is keyed differently from the 24-pin ATX connector, you might have to jury-rig something, and as for figuring out the wire arrangement, the only way to do that would be to get it either from the motherboard manual (if they list it), or by taking a look at pictures of the actual male 18-pin connector and figuring out the pinout yourself.
Heatsinks are in!! God I hope they fit
Posted via [H] Mobile Device
