Skipping the detecting hard drive screen...
Phranq
"IDE Hard Disk Detection - This part of the BIOS Setup will detect your hard disks for you; and you can save the configuration. If you configure your hard drives here, you will not have to let your BIOS auto-detect the drives every time you boot up, which will save you time. This is a rather simple process and I don't think I need to explain it further. "
Is there any way to do that with an SATA drive? ya know it detects the drive with the ...... then shows your drive ;) can't I get it to skip that.
