Sketchy eBay Water Pumps
ak47is1337
Hey guys.
Water pumps for liquid cooling systems are expensive and you're basically limited to versions of the Laing D5 (Swiftech MCP655 I believe) or the other Swiftech pump, the MCP355. Why not just get a small hobby water pump from eBay?
Check this out..7m of head? The highest-performing version of the MCP655 has only 4m. It also has the same rate 5 year capacity as the MCP655 too, granted it's Chinese and from eBay.
http://www.ebay.com/itm/DC40E-2470-...059?pt=LH_DefaultDomain_2&hash=item43b0e60f5b
Also, this is the real kicker, it's only about $22 US with free shipping. Uses some kind of screw-on barbs, I think 1/4". What do you guys think about using one of these?
Thanks
Edit: I think the MCP655 might have as much as 10 ft of head. Anyway, you could buy three of these things for the price of an MCP
Oh boy...
Chinese pump specs are for running at 24v, and they are posting maximums, not nominal, so real world will be alot less...
MCP655 pump specs are for running at 12v, and nominal values so much closer to real world expectations.
7m of head for the chinese pump is maximum, and will typically run far, far under that type of power output. They want you to think its better than it really is.
4m of head for the MCP655 is nominal, not maximum. Double its voltage to 24v like the chinese pump and youll get alot more head pressure
Flowrate for chinese is 620L/H max at 24v, so real world again will be less.
Florrate for MCP655 is 1200L/H nominal, at 12v
If that isnt enough to show you the chinese pump is a piece of crap compared to the MCP655...i dont know what to tell you. Seems that the chinese pump requires twice as much power to perform half as good as the MCP655.
Also MTBF for chinese pump is 30000 hours, vs 50000 hours for MCP655, so the MCP655 can be expected to last almost twice as long, and thats assuming this chinese pump was put together well.
I'm using the 12v - 5m of head version and it's been running well for the past 3 years. In fact, I have my rig sometimes running 24/7 and it hasn't hiccuped once. It's also a LOT quieter than a Laing DDC 3.2.
To be fair, just about everything is quieter than a DDC.
Also i dont mean to say the chinese pump wont work, but to compare it to the D5 is a joke.
interesting points from both of you. nissanztt90, would it even be possible to wire an MCP655 for 24v? Also how do you wire the 12/24v version of this pump? For the 12v, would you just hook it up to a molex connector? Thanks again guys.
Operating voltage for MCP655 is 8 to 24v so yes its possible but you will need know a bit about electronics to turn 12v from a pc PSU to 24v. To run either pump at 12v the easiest is to just use a molex connector. The MCP655 comes with a molex connector. If you do go with the chinese pump and plug it in with a molex you can pretty much take the specs listed and cut them all in half for max values, which will translate to even lower real world values.
Running 2 of the chinese pumps in series really isnt a bad idea...2 of them is still cheaper than an MCP655, you wont get quite the same performance but it will be getting up there...and you have the redundancy of 2 pumps in case one fails...and thats never a bad thing with chinese stuff but then theres the fact that you probably cant mod them for a better top, and 2 will take up space...all in all...spend the money on the MCP655.
