I usually partition cause it's easier for me to separate the OS from the music, movies, and everything.
If only one partition is better, I'll just create a Storage folder then, and use the 2nd HD for backup.
Only one partition or 2????
The only reason I would make an extra partition is to store my OS backup.
You do realize that some people just like keeping a clean image that they can restore from to set the OS back to default, but also keep an external hard drive for backed up data, right???You do realize that's not a real backup, right???
It's still stored on the same physical disk.
It's in the details I guess, but how the hell would I have known that from what you posted???You do realize that some people just like keeping a clean image that they can restore from to set the OS back to default, but also keep an external hard drive for backed up data, right???
*sigh* .... I just said that's the only reason I could see someone dividing up with partitions now, a person that may not have an external drive to store a clean image on.... quit nit picking the details, I thought you were better than that(Which is why again it seems crazy to double up on backups when one will suffice).
No"Want a performance boost? Run with 2..or more..hard drives. Leave each drive a single partition. Move the pagefile.sys to a hard drive/spindle other than the C drive. Having your virtual memory on a different spindle than the OS is where your good boost is."
Really?
Benchmarks show there is no performance gain using Readyboost, when using more than 1GB of ram in Vista.yeah, that would help system performance.
Or under vista you could just buy a cheap USB key and use readyboost.
Really?
There are so many other things to 'gain performance' than suggesting buying another drive just for the page file. It may have a slight loading time drop because it's not reading/writing to the same disk but it would be so insignificant.No, I typed that because I was bored.
Yes...REALLY. Depends on the applications of course, those which pull from program directories heavily while in use. Quite a few of the heavier games for example...while loading maps in changing levels..some data gets written to virtual memory, your OS is doing other things in the background. Tis better to have those 2 hard drive intensive jobs split across different spindles, instead of competing for the read/write cycles of the same spindle.
Tips from the server world that can trickle down and benefit desktop PCs under heavier use.
I'd have to respectfully disagree.
Moving to a different physical drive, like you suggest, is a performance boost, yes. However it's really not enough of one to warrant screwing with.
Just my opinion of course, but I've seen no benchmarks that have shown moving the pagefile to a different physical disk with any reasonable performance increase.
When the game Vanguard Saga of Heroes launched, I tested it by putting the page file on a second drive and there was absolutely no difference in loading. And at this time this game was horrible with page file abuse because it was CONSTANTLY loading.
Wow, such a big conversaion over something simple. I have 2 partitions on my 640. One is 100 gigs since that's more than enough for OS/Apps/Games and the other is just under 500 gigs for media files/documents/etc. I also change the location for the documents/video/music/favorites/saved games to the 2nd partition. I like to reinstall Windows a lot it appears so I just format C: and install and everything on D: is still intact.
Now see I have never understood why people do that??
the Pagefile is still on the same drive however you moved it to a slower part of the drive.
If your going to have a single disk....leave the pagefile in its default location.
