Size Constraintd
Mysticcal
Hello, im considering buying 4 ZM-OP1 80x80x15 Slim Fans and placing them inbetween the chais and the actual Case plastic on a Raidmax Scorpio 868, Id like to ask, if anyone knows if this will fit, before i spend 10$ a fan, and is it really beneficial? i mean, they'll be close to the plastic, thanks
maybe posting a link to the actual fans and case your doing this on. Since i know im probably not going to go out of my way to search for this stuff, then ponder my opinion. But if it were right here at my finger tips...
well if you have a fan that you can pull from someplace, then put it on the case, tape it down, and put the bezle on and see if it fits, i dont know about your case, but i know that i have dremiled out a grill on my bezle, and mounted a fan between my bezle and my case, (red led fan it looks kick ass)
That being the fan, wanting to fit it
