Site Response
w1retap
I'm still having problems randomly with the site not responding for about 30 seconds when I click threads or go to make a reply.
Here's the traceroute. I circled a timeout in red that I noticed.
I just ran it and I'm getting the same * timeout.
Probably doesn't matter since it's supposed to re-direct, but the preferred/most direct way to access is via just hardforum.com without the "www". Maybe try it without that?
Same without:
or did you mean with the http?
Lethal, you just shaved about 2s off of EACH of my page loads.
Now I can be MORE of a post hog :)
The timeout you're seeing on that traceroute is just a hop along the way that does not respond to ICMP requests. Load times are not because of routing issue
Thank you, I had no idea and that really did make a noticeable difference on my end.
