Single slot GPU WC block
d3fc0n5
hey guys i have a dfi sli. i want to get my 6600gts wc but i cant use a dual slot block cuz i use both PCI slots. on for a ATI 7000 for my lcd and one for my SB2zs i havent found a single slot cooler. do they make them. or and i goign to have to which back to my MSI SLI for the 3rd PCIslot
How much do you want to spend?Do you currently have a water cooling system?
i was think under 50 a block for the gpus. imm still working on geting the parts for my WC setup. its going to be 1/2id
IIRC Polarflo makes about the thinnest GPU cooler on the market right now. Also, DD makes a low-profile version of the Maze4 GPU.
The Innovatek and AquagraFX 6600 combo coolers are mostly single slot solutions though new they are out of your price range. You might be able to pick them up used in your price range though :) Depending on how fast you need them Aqua Computer will have the TwinPlex Pro available in about 3-4 weeks. I think they are only about 11mm thick (.430").
:rolleyes: used? Let's stay inside his price range. I doubt he has Aqua computer stuff now, so there'd probably be conflicting tube/barb sizes too. THat adds more for adapters, AND he'll have to worry about his flow being restricted.
Get the Maze4 low profile. You can get a deal on two of them at Danger Den. Here:
http://dangerdenstore.com/product.php?productid=169&cat=69&page=1
It's $116 but it includes 16 ramsinks which would be $40 separately. Plus you probably want ramsinks if you are gonna overclock.
If you don't, then see this:
http://dangerdenstore.com/product.php?productid=161&cat=0&page=1
$45 w/o ramsinks, $64 with (so the deal will save you $12).
You have 6600GTs, are you planning to upgrade ever? Because the Maze4 has one way to mount to 6600 series and older and another to mount to 6800 and up. If you are planning to get better video cards ever, you will probably want to get both sets of hardware. It adds $4.95 to the price, so $49.90 w/o ramsinks single, $121.90 with the deal.
The low profile Maze4 is verified (by danger den) to be compatable with the following motherboards:
"Known compatible Motherboards:
ASUS A8N series
MSI K8N Neo4 Platinum SLI series
GIGABYTE GA-K8N SLI series
DFI LANPARTY UT nF4 SLI series"
well since the Aquagra is over 100$ us i dont think i could but two of them and if i wanted to upgrade to a 6800 ultras when they drop in price. id have to buy new blocks. i think im going to go with the maze4 block thanks guys
