single slot GPU cooler
simoriah
Looking for a single-slot GPU cooler for an ATi 9600 series video card. My fan's shot and I might as well just add the video card into the cooling loop.
Suggestions for a copper block?
What type of loop do you have, I would look at the silverprop fusion blocks, the SL version is only 19mm deep, and the HL version is much taller. Also the new DD Maze4 might be low enough. I think the MCW50 might be a bit bulky.
Closed loop with a couple of DTek TC4's on the cpus and a DTek chipset block on the northbridge. Hydor L30 pump and a big friggen heatercore (6x12x2) to dump the heat.
