So I have an idea for single slot coolers. Since most single slot coolers these days simply blow hot air around inside of the case instead of expelling them out the back, I came up with this idea that would blow it out the back of the case:
So basically the PCB would be similar to those found on low profile cards. A heatpipe based cooler would be on top of the PCB vertically, and there would be a vent about half the height of the card in the back where the hot air would get blown out by the centrifugal fan. However this will only take up one expansion slot. This leaves room for only a single DVI or VGA connector so they'res two of them on a cable.
Any thoughts?
Any thoughts?
