Single Slot Adapters for 8800's?
smiller303
OK, so currently I have 2 EVGA 8800 GTS 640mb video cards. I have Swiftech Stealth waterblocks on them and the Dual PCI slot adapters are no longer needed.
I would at least like to be able to use the slots for USB / Firewire internal extension or for small video capture cards in the PCIe x1 slot.
Or, if someone knows a good way to saw it in half? Although, I would prefer to buy one.
Thanks for any help!
Fine hand eye coordination and a Dremel?
BE CAREFUL!!! :D
Post results with picts! :)
BE CAREFUL!!! :D
My brother has an 8800GTS but I never really bothered to look at it that closely, but on every video card ive owned, you could take it off, You would need to unscrew the part that your monitor cables screw into (not that hard, their made to be taken off, atleast on my x1950pro you can). Then take a dremel to it.
BE CAREFUL!!! :D
Do to the existing scar from the middle of my thumb to the top of my wrist when I used a Dremel with the extension and the saw blade adapter, I still would prefer buying one.
I know I can remove it, but i need to support it from the slot due to the weight of the card and the pressure from the DVI connector.
Thanks though -
Watch out though. I was thinking of buying two of those (I ran 8800GTX SLI using two EK water blocks a while back) but a PCI card wouldn't fit directly underneath the cards due to the blocks. Not sure if the Stealths are the same in terms of thickness.
