Eurypterus
- Oct 7, 2009
Hi all,
Lets start with the specs
Computer 1
CPU: i3 530
MB: gigabyte H57M-USB3
RAM: 4gb kingston valueram
GPU geforce GTX280
1 Optical drive
5 Hard Drives
PSU: Thermaltake TR2 W0070RUC 430W
Computer2
CPU: i5 3570
MB: z77x-udh5
RAM 8gb kingston hyperx 1.65v
GPU: geforce 660ti
1 optical drive
1 ssd
1 hdd
PSU: coolermaster real power pro 1250w
Both systems run stock, no OC
The thermaltake psu cannot run the gtx280 but will power everything else in computer 1.
The coolermaster psu will power everything computer 2 and the 280 gtx in computer 1.
Both computers will be on simultaniously. I will common ground the cases to each other
Is this even possible (especially with both systems under load)?
The cooler master psu has the amps, watts, and connectors to run both cards. But from a technical standpoint, would it work?
My thinking is: that while possible, this is not an ideal situation and the obvious better option is to get a new psu, but this is a very temporary setup.
Worst case scenario if this would even work is that either computer losses power. What would happen in that case? BSOD? Something gets fried? Nothing?
Thanks a bunch, really appreciate any assistance
Computer 1
CPU: i3 530
GPU geforce GTX280
1 Optical drive
5 Hard Drives
Computer2
CPU: i5 3570
MB: z77x-udh5
GPU: geforce 660ti
1 optical drive
1 ssd
1 hdd
