Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
For a large number of scenarios and flow rates, more suitable to what is seen in people's typical setups, double-pass is better. For high flow rates (>8LPM) and and a single-row core, single-pass can be better. At lesser flow rates for single-row cores, it's a bit of a toss-up as to which is better, but for flow rates <4LPM, double-pass tends to work better. For double row cores, then double-pass is almost always better unless talking about stupendously high flow rates (>4gpm).
The above is just broad generalisations, it's really on a case-by-case basis, and it can also depend on how well/poorly the end-tanks are being implemented in the double-pass scenario.
Generally speaking though, double-pass is better in terms of a "safe bet". Unless you're provided with information that details otherwise, or the radiator has been purposely built with the advantages of single-pass in mind (rather than its single-pass implementation just being driven by ill-informed market demand), then double-pass is almost always the safer option to go with.
