- Jan 20, 2005
Hi guys first of all let give you info on my current system
Specs:
Currently I'm only water cooling the processor using the following parts:
Here's a picture of my system so you can see how it's setup
Now my the problem is that is getting mighty hot in Southern California ( I'm about 50 minutes from downtown Los Angeles San Dimas area) & I would like to water cool the video cards for two reasons. First the fans are freaking loud is like listening to a F-16 taking off for hours at a time. And two as you can see the radiator is place right behind the pci-express slots, meaning all the heat from the video cards is getting dump right behind the radiator.
So my question is can I add 3 vga water blocks to my current loop & can my pump/radiator handle the extra heat? I already pick up 3 x Swiftech MCW80 Universal GPU Waterblock with a couple of sets of Enzotech BCC9 / BMR-C1L Low Profile Forged Copper BGA Ramsinks.
My other option was to add a second loop just for the processor alone using the following parts that I already have (except for the second radiator I still haven't bought it):
I would really appreciate if someone can give me some ideas of what to do. I know the S&D PRO-120 radiator is a bit small but I just can't fit anything bigger inside the pc. There's enough room for both pumps and the PRO-120 radiator at the bottom but that's it. I'm not planning to overclock the video cards at all I'm just concern running 4 blocks might be too much for my system to handle.
Thank you
Specs:
- Q6600 2.4 overclocked to 3.8 voltage 1.416
- 8 gigs of pc8500 DDR2
- 6 x 1 tb sata drivers
- 3 burners
- 1 4850X2 2 gig + 1 4870 1 gig Tri-setup or whatever the hell people call it
- 7.1 Omega sound card
- EK-RES400 Rev.2 Reservoir
- Laing D5 Vario/Swiftech MCP655 Inline 12V DC Pump
- Swiftech MCR320-Radiator
- Swiftech waterblock (cant remember which version)
- XSPC Delta V3 Universal CPU Waterblock
- S&D: PRO-120 Radiator from d-tek (they're dirt cheap)
- I can either pick up the D-TEK Bay-Reservoir or used my old Swiftech MCRES-MICRO Rev1
- An old Eheim 1048 pump
Thank you
