Your first benchmarks looks invalid; try CrystalDiskMark instead or the "File benchmark" in HDTune Pro. Depending on controller, HDTune would give you incorrect output with default settings on many RAID arrays.
Still it is single queue depth I/O; not how any actual program would access your disk(s); it would use the filesystem instead. CrystalDiskMark, AS SSD and the File Benchmark in HDTune Pro use the filesystem instead to do I/O. Even with 128KiB blocks, that would mean it uses multiple queue depth and send several requests at once for sequential I/O; read-ahead and write buffering.
The small dip may just be some reallocated sectors in that spot; shouldn't be anything to worry about.
