I just got the uber long 8800GTS and it runs smack into the SATA connectors on the motherboard (the case is big enough that it doesn't actually interfere with the hard drives).
On my board, there are 4 SATA slots. I had been using them all for DVD, OS drive and 2 mirrored DATA drives. But I'm willing to drop to using 3, maybe even 2 if I absolutely must, as I plan on moving the data to a centralized server anyway.
I'm asking about this because I've tried tons of things but my system still isn't stable. The actual card/SATA interference is such that the card completely blocks one of the SATA connectors from being used, so I dropped down from RAID to just a single data drive... but then a capacitor from the video card still presses up against the other data drive connector.
I don't know for sure if this is causing the instability... I've gotten so many different OS crashes, program crashes, blue screens, etc that I haven't narrowed it down yet.
Some troubleshooting I've done:
I've also tried to do a Windows repair to fix drivers, but that failed and I formatted the OS drive. It's still terribly unstable!
So anyway, the main question remains... could I run the video card in the other PCI Express slot?
The board is a Gigabyte K8N-Pro SLI.
Other pertinent specs:
Corsair HX-620
The rest of the details are in my signature.
- Running with one data drive removed but put 7800GT back in to see if it's the video card or a power deficiency.
- Running with both data drives removed (seems the most stable but still not back to 100%)
- Running with RAID enabled with that one drive.
- Breaking down the RAID array manually, disabling RAID on all ports.
Corsair HX-620
