Mccaula718
- Dec 11, 2007
Ok so i just bought a new hdtv and i want to use my old hardware(second rig in sig) for a htpc. I know single core may be cutting it but i was hoping the video card could offset some of the load. I can play hd on youtube fine, and that is without any gpu acceleration bc flash doesn't support it til the new update next year.
Does that mean my pc will def be able to handle bluerays if i buy a drive since they support gpu acceleration?
