System spec:
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128519
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
It is a budget build for someone looking specifically to play BF3 @ 1920x1080. I didn't get all the parts from newegg but was easiest to link from. Only thing left to buy is a GPU. All other items were bought on sale & with coupon codes/shocker discounts. (so a little cheaper than links currently show). There will be no overclocking. I am looking to set this up and pass it on.
Left with $270 with shipping to spend on a single GPU. I'm looking at either the HD6950 or GTX 560Ti. At the 1920x1080 resolution BC2 seemed to favor the 560 over the 6950 cards but I haven't seen any BF3 release benches yet with a rundown of the cards performance/comparisons. Basically I have a few cards in mind to see what you think or give an alternate option:
1) $249 A/R http://www.newegg.com/Product/Product.aspx?Item=N82E16814130657
2) $249 http://www.newegg.com/Product/Product.aspx?Item=N82E16814125385
3) $269 http://www.newegg.com/Product/Product.aspx?Item=N82E16814161372
4) Your input
4) Your input
