Please attach a link to a card that will support 2 monitors that can run 2560x1440p resolution. Thanks
That link sent me to a list of cards on newegg. Only 1 card on that list had dual d-dvi. the radeon r9 290x Thanks
nope, all of those cards are Dual Link DVI.. yes, the 290X have 2 Dual Link DVI-D. the rest have dual Link DVI-I both are Dual Link. whats the difference? DVI-D Are digital Only. DVI-I are Digital-Analog, and its actually used to allow people use DVI to VGA converters for Analog VGA monitors, nothing more,
im afraid you are wrong here. i actually just got off the phone with newegg returning my two gigabyte r9 290s because i made the same faulty assumptions as you. Here is one random nvidia card i picked from your list:
http://www.gigabyte.com/products/product-page.aspx?pid=4647#sp
if you look at the specs, only one port is dual link, so only one dvi port is capable of running 1440p, whereas the OP is looking for 2x dual-link DVI ports. The 290 card i picked up was even worse. If you look at gigabytes specs on this, it reveals that neither port is dual link!
http://www.gigabyte.com/products/product-page.aspx?pid=4884#sp
Newegg really needs to update their filters to incorporate # of dual link DVI ports, as most people buying higher end cards are going to be running higher resolutions than petty 1080p.
That card is so sexy!
