I was wandering how much better a watercooling setup using a single 120mm
fan radiator would perform compared to an XP-120 heatsink/fan combo.
I'm using an Antec P180 case so it's rather to mount a dual 120mm radiator
on it internally without having to hack the case.
I'm also looking at only cooling the CPU, not the video card.
I also would like to overclock. My X2 4800+ can do 2.75GHz but the vcore has
to be around 1.55v which gets my temps way up to the mid 50 C on iddle with
an XP-120 and a quiet 120mm fan.
