For those of you who are interested.
Cheats: open the console (~) then type the following.
sv_cheats 1 - to enable the cheats (sometimes you'll get a message that says they ar enabled and most of the time you won't)
god - self explanatory
noclip - no clipping.
cvarlist - lists all possible codes and commands
Those were the only ones I've found by chance while looking around in the console.
Secrets:
If you go under water in the beginning of the game and swim under the pier you'll find a very bizzare looking fish. It'll appear several times during the game.
There is a room in the 2nd or third level that contains some weird jumping orb thingies and a shotgun.
Phone numbers: (These are the ones I'm most concerned about.)
So far the only phone number I've come across is for a company called TightFx (video card I'm assuming).
TightFx = 1119
Post up any other phone number secrets and cheats you've come up with. Mainly phone numbers though.
Secrets:
TightFx = 1119
