Simulated Sine Wave vs Pure Sine Wave - Worth the upgrade for a consumer power supply?
Discussion in 'Power Supplies' started by bigblueshock, Jun 10, 2019.
  1. bigblueshock
    bigblueshock [H]Lite
    78
    Oct 27, 2017
    Just wondering on peoples takes with Simulated vs Pure Sine Wave UPS's. Currently my home server has a Pure Sine Wave UPS (Cyberpower in particular), however my Gaming PC has a Simulated Sine Wave (APC) Battery Backup.
    I'm contemplating changing out/upgrading the APC and getting another Cyberpower pure sine wave, but I'm 50/50 on spending the money, or if it's even necessary.
    I haven't had any problems with my APC, at least I don't think. However, when my power glitches or goes out, am I hurting my Power Supply by not having a pure sine wave?
    Should a higher end consumer power supply be able to handle simulated sine wave without issues?
    Basically, I'm unsure of what consumer grade power supplies "should" be able to handle. For instance, my Gaming PC on the simulated UPS is a Corsair HX1050.
    Thoughts?
  2. Meeho
    Meeho [H]ardness Supreme
    4,303
    Aug 16, 2010
    If your PSU handles switching to battery power ok, there is no need to change your UPS and you're not hurting it.
    bigblueshock and Brian_B like this.
  3. JRZoid
    JRZoid [H]Lite
    71
    Feb 1, 2019
    For testing mostly..manage to have a unit that can read/display any of that correctly and not burning up doing so.
    Something suspected in whatever unit...yeah that shows up on the wave dude...and that's mostly WALL/Low frequency oscillation/BAD.
    bigblueshock likes this.
  4. pitingres
    pitingres [H]Lite
    76
    Jul 25, 2018
    If you're driving a computer with the UPS, I wouldn't worry about the waveform unless your PSU is crap. (Which the HX certainly is not.) You might get a little buzzing noise from the PSU while it's on battery, or not.
    N4CR and bigblueshock like this.
  5. DrLobotomy
    DrLobotomy [H]ardness Supreme
    5,614
    May 19, 2016
    If it ain't broke don't fix it.
    Spend that cash on a new SSD or spinner for backups.
  6. bigblueshock
    78
    Oct 27, 2017
    Thanks guys. Much appreciated. I was leaning towards that way.
  7. N4CR
    N4CR 2[H]4U
    3,721
    Oct 17, 2011
    Have run sim for PC and critical entertainment applications without issue. As already said, a decent PSU won't mind either way.
    You might get noise from the UPS on battery though keep that in mind. Some can be pretty loud, plus cheaper ones can also make noise on AC.
    bigblueshock and drescherjm like this.
