Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
You can only go from basic to dynamic drive types per physical disk. You can't go from dynamic to back to basic. The only way to do that is by backing up the dynamic drives, delete them and recreate them as basic disks.
I'm sure that's how it was with windows 2000, and I don't think it's changed with xp / 2003.
Do ASR backups contain disk configuration information?
1. for all I know, one cannot revert from dynamic to basic.
2. images with large areas of a single color and few gradients -> use PNG or GIF, not JPEG, which makes text hard to read due to artifacting
