Simple Tech - 2TB Pro Drive "Quad" - $199
TheBluePill
Pretty Good Deal, As you get two 1tb Drives in it and a nice enclosure that supports SB 2.0, FireWire 400, FireWire 800, and 3Gb/sec eSATA... With Raid.
Features
Two drives in one - Duo Pro gives you two ways to save: Speed Mode (RAID 0) and Copy Mode (RAID 1). Speed Mode works across both disk drives to read and write your files much faster than using one disk alone. Copy Mode makes an extra copy of your files on the second disk drive, so you always have two separate copies for extra protection
Two levels of backup protection - Duo Pro includes Fabrik's backup software suite that makes it easy to steer clear of life's little disasters and protect your irreplaceable pics, flicks and tunes from spilled drinks, curious toddlers, fire or theft.
Powerful, yet simple to use - saves copies of your stuff on both your Duo Pro Drive and on encrypted, secure servers for ultimate online backup protection.
Works with - USB 1.1 or 2.0, FireWire 400, FireWire 800, and 3Gb/sec eSATA. Backed by a three-year warranty, compatible with both PC and Mac computer, the Duo Pro is high performance storage and backup made simple and affordable.
__________________________________________________________________________________________________________
Product Detail
Part number: PROD2000Q
UPC: 705487176742
Capacity: 2000GB
Form factor: 3.5"
Interface: eSATA/USB/FW400/FW800
Warranty: 3 Year
Performance
Dual-Drive Performance storage and backup with Speed Mode (RAID 0) and Copy Mode (RAID 1)
Quad interface for plug and play flexibility: USB 2.0, FireWire 400, FireWire 800, and 3Gb/sec eSATA
Compact design stacks or stands upright Award-winning Fabrik backup software, including 2GB free online backup
Quiet fan for reliable, cool operation
Security lock slot
Friendly, free unlimited technical support
PC and Mac compatible
http://www.frys.com/product/5700822
Good deal as it would cost more to purchase something equivalent and build it. How is this model? What sort of drives are inside?
anyone used this enclosure before? the other simpletech that was up a few days ago had horrid reviews
fireproof case? or are you supposed to bring it onsite just for an immediate backup then remove it promptly offsite?
Fireproof and theft-proof*
Requires fireproof bolt down safe. Not included.
btw, i bought the enclosure few minutes ago, moving some files to it. backup from my media server.
Got the same enclosure a few weeks back with a cheap MIR deal (without the harddrives)... Reviews didn't look good at all, anyone actually have experience with this item I'm not confident in it enough to order its own set of drives just yet..
Last time I tried something like this the hard drives were ridiculously hot and I decided to return it.
This looks like a good deal if it works.
