Simple question.
slowbiz
I cant seem to find a legend for this, so I'll just ask.
What do the different envelopes next to each thread mean? All of mine are yellow and have a black hole through them, and no one elses do. Does that mean something negative, or is that just telling me that I've posted there?
That's just the "you posted" notification.
The key at the bottom of each forum will tell you that :D
Dont feel bad! With vbullten3, you can customize them, so every fourm i go to that uses v3 seems to have a differnt set, and they are all crazy! i still cant even figure some of them out without the guide
