wee96 said:...The psu isnt bad if its spinning the fans up.
jonnyGURU said:I said "everything but the CPU."
jonnyGURU said:Well.... I wouldn't say that's necessarily true either.
All we know is the PC won't post.
Pull the board from the case so we know we're not shorting it on anything like an extra stand off, strip the board of everything but the CPU (no memory or video card either,) fire it up and see if you get a POST beep code.
josboh said:Ok. So here is where I am.
under jguru's instructions, i removed everything BUT the cpu and I actually got beep codes. 1 long 2 short. When I referenced the code back to the manual it showed that it was somekind of video or memory code.
