Interloper
- Aug 10, 2004
Hi all
I am somewhat new to OC'ing but am a scientist at heart and by degree.
When I built my last system I wanted the fastest processor available but this week I finally realized that the damn thing can reach 76'C with no overclocking and what I thought was more than conservative cooling!!!
All I am looking for here is a reliable solution to cool a NON-OVERCLOCKED P4 3.2GHz. I would Really like to be able to run at 3.6 - but currently under a high load I have instability issues which I believe are related to cooling.
I have a stock p4@ 3.2GHz that is capable of posting and booting to windows at 3.7 with instability. Runs pretty well at 3.6 but under heavy load it will crash. I think that myproblems are all cooling related. Ram is rated for 275 FSB speed so must be something else.
WHile running Video processing apps, I can reach temps of 76'C for prolonged periods of time..
Bought a Thermaltake Subzero TEC unit for about $140 when I built the system to help things, but under load it just can;t handle things, even when I'm not overclocked.
My question for the forum here is this:
I want to run a P4 3.2 at 100% load and *IDEALLY* would like to run it at 3.6 GHZ 100% load and have sufficient cooling so as not to top 59' C at 100% load or even better not to top 49'. For any who do heavy video proc stuff you all know this is heavily CPU intensive stuf and probably have similar concerns.
I did run my CPU at 76"C for about 8 hours overnight before I realilzed the problem then I removed the case cover and cranked Room A/C which lowered the temp to 63'C which is where it remained for about another 15 hours during a video conversion process. (100% load)
I am not happy with having a CPU less than 6 months old with such a high temp and am just looking for help on where to go from her for better cooling so I can do these video projects without topping 60'C
please help as to how I should proceed - I thought that the Subzero Unit would be all I needed but It works best when you are at Idle or playing a fairly simple game - Video editing it chokes on.
Thanks
Thanks
