simple little question about startup date
heliotrope
I am wondering if there is anywhere that a Windows 2000 or Windows XP computer keeps the date that the computer was started on anywere? I am wondering how long I have been running the computer without restart.
thanks!
Just go into the task manager and look at how long the system idle process has been running. There's also hundreds of free utilities that tell you system uptime.
I believe the easiest way would be getting the info from the "systeminfo" command, which is already present in Windows XP.
MS had a tool called uptime.exe you could dl and put in the sys32 dir and would show u the uptime when run from the command line
