I've just installed Server 08 with hyper V. This server is a domain controller/dns server/gate way to the internet (Two nics) and all the machines on my network specify the DNS server 192.168.X.X. I've now got WHS as a guest operating system, and i'm trying to connect that machine to the internet. I've also installed a third NIC into the server so that it has a dedicated line to the lan. My question is: On which machine would I edit the IP settings? The guest machine? On the host i've got the physical NIC and in the settings it specifies only "Virtual Network Switch Protocol" with tcp/ip 4 and everything else unchecked. Then I have the actual virtual nic, plus the nic that shows up on the guest machine. I'm not sure if i need to configure both the virtual nic and the guest operating system nic or what....
Any ideas?!?!?!?!
Any ideas?!?!?!?!
