- Nov 27, 2006
This is probably nothing new for our readers that are knowledgeable about interference caused by electromagnetic fields but it is good info for us laymen. By simply using some ferrite beads, you can eliminate that buzz that plays over your speakers from the GSM device when youre using it to play music. Nice!
For those who dont know, ferrite beads are housed inside the little nub found at the end of some USB cables. They can be cheaply purchased at most stores that sell computer parts but if you happen to have an extra (and disposable) cable handy, this simple solution can be had for free.
