PureQuaternion
- Jan 25, 2012
Hi guys-
Just did some simple work on my 650D to make a video card support bar. I used about 9.5 inches of aluminum bar, along with 1/2" L brackets and screws. The bottom L-bracket secures to the case using a thumb screw and one of the holes from the PSU support bracket. The L-brackets do not actually attach to the graphics card, but rather rest just underneath one of the RAM heatsinks. I could've designed it differently, but for one saw cut and three holes drilled, this was pretty easy.
There are two L-brackets in place for triple-thick Asus GTX 570's. I'm running one now but may grab a second in the future for SLI.
Next step is to paint it all black to match the case.
