Ok, So this is what i am looking at doing. I bought a Q6600 and an 8800GTX a week or so ago and i have been contemplating where i want to go with them. I have dabbled in water cooling in the past but not a whole lot. I am running the DFI Lanparty P35 Board the following is what i am looking at as a set up:
D-Tek Fuzion cpu block
D-Tek Fuzion chipset blocks
DangerDen 5 1/2 drive bay reservoir
Swiftech Stealth Extreme Duty G80
Black Ice Xtreme 2
Swiftech MCP655 Pump
The case i plan on putting this all in is the Cooler Master Stacker 830, so i am sure i have enough room for it all.
Now what i was thinking was running it all in a single loop. Going gpu, nb, cpu, sb, rez, pump, rad.
Now those two areas are where i need advice. i have looked around in the forums and found a bit on it but not much guidance.
So with that Thank you for reading.
Black Ice Xtreme 2
