OK I need the [H]ard Community to help me on this one I have seen the ft02 case and I like it but here is the catch I have a current mobo setup to transfer and I want to know will the black interior or the red do me best I will be putting the ATI and AMD logos on the window and building an AMD/ATI based/themed rig kinda like the Cooler-Master HAF 932 AMD edition, But I dont want LED's I want this professional and clean aesthetically (visually) pleasing and balanced.
Well I know there are people looking at this and while I am at it I might as well go ahead and do this any and all suggestions for cable management sleeving colors new heatsink and a brushed 5.25inch faceplate that will match would be nice I want to get a faceplate that I can put a blu ray player behind and will look decent as a BD drive takes away from the brushed clean look and I don't like this
here is a pick of the inside of my rig
I will be doing away with all blue LED's including the fan in my ocz gameXtreme Will be replacing them with modded cooler master r4 fans with black housings and red blades. I am going to be buying a ATI Radeon HD-5770 soon as well. i like the red int. but with me having a blue/black mobo is this possible?? to pull off and make it look good.I will also be buying Corsair Dominator GT ddr3 dual channel mem for the rig I am trying to figure out if a black interior or red would look best. I want it to be this clean
this is how i plan to do my fans and in the back for cable management i will replace the psu fan with a non LED red modded fan as well i can do the cable management so dont worry about that and remember the ram is red colored in case you are wondering
http://cgi.ebay.com/Corsair-CMT4GX3...z-C9-DDR3-/280546336577?pt=LH_DefaultDomain_0
thanks for all help
the cases
the black
the red
And the same way that Lian Li etched the AMD out of the Plexiglas at the bottom left i intend to do the same and put the it Crosfire X on it to
and everyone please check this thread if you read this one as it does apply it is a blu ray and i want to know if it will match the case
http://hardforum.com/showthread.php?p=1036056108#post1036056108
EDIT or well update i wanted everyone to knwo i am thinking unless i can get a thermaltright true black used and chep this is my otion for a new heatsink
http://www.frozencpu.com/products/1..._AM3_940_939_754_K8_.html?tl=g40c14s881#blank
and may have this psu unless i can get a used corsair hx650 or 750 cheap
http://www.frozencpu.com/products/9...er_Supply_-_OCZ600MXSP-B.html?tl=g11c26#blank
thanks for all help
the cases
the black
the red
