morpheus6d9
- Mar 11, 2005
IDversusEGO said:that looks like a great case for my lower end clients. pop a 6150 board in there with a 1u cooler and you have a great little solution. cost?
Dew said:Showing up around $200 on Froogle.
No, check the link it comes with a fanless PSU.valve1138 said:Ouch.
Plus you have to mod in an ATX PSU.
qdemn7 said:No, check the link it comes with afanless PSU.
Fanless 120W DC/DC board & adapter
No, it comes with a DC/DC adapter which is fine for an Epia system but if you want anything better then you're going to need to mod the case for a 1U PSU (if it will fit in there).qdemn7 said:No, check the link it comes with afanless PSU.
Theres a door on the case that hides the drive and ports.Cax6ton said:Specs say it requires a slimline optical drive($$$), though there seems to be no front port for it...or it's hidden behind a door.
I wish they had used a different PSU like maybe the one that comes in the LC02 or something.Funky external power supply that will either be a wall wart or a line lump.
Doesn't bother me, it's for a slim client system so chances are you only need on card in the system if at all (a good 6150 mobo and some modding could easily leave that single slot open).A riser card setup that can only use one slot.
That is kind of annoying.Nowhere to integrate an IR receiver.
As mentioned above this is nearly perfect for a client system which only needs a single HDD in there to load the OS on, everything else should be handled by the server. For me though the only thing that is a potential deal breaker is the PSU.Only enough room for one hard drive, so if you're not on a network you'll have space issues. Nice looking box, but for those issues and that price I think I'll pass.
Ooops! You are right. DOH!CrimandEvil said:No, it comes with a DC/DC adapter which is fine for an Epia system but if you want anything better then you're going to need to mod the case for a 1U PSU (if it will fit in there).
