Hi I recently built a new pc on a Silverstone TJ09 i also bought a used Radeon HD 6990 which came with an EK waterblock already installed so i decided to watercool it. I got a hand me down pump reservoir and radiator for it but it doesnt do the job its only a single 120mm fan radiator.
I was thinking of buying the internal rad support but can that house a triple 120mm radiator or jus a dual 120mm fan radiator?
I do prefer everything to be internal, so any suggestions about whats the best radiator that can cool a radeon HD 6990 and possible cpu processor corei7 980x with heatkiller rev 3.0
Thank you
Thank you
