silverstone TJ09 question
Dutt1113
Is the the flat bar underneath the mesh on the TJ09 for structural support of the case or is is there to support the mesh or something. I'm going to be putting a double 120 radiator up there and I was wondering If I could just cut out the bar and screw my radiator to the mesh from underneath?
im not a 100% sure on it.. but if you are removing it and mounting your rad there.. wouldnt the rad give it some structure then to replace the bar?..
