Silverstone TJ09 and "BTX" profile...
seb87
It's possible to reverse the mb tray of this case lika a mb BTX ?:)
on the manual there isn't ...but with a mod ? like the tj07 ?:confused:
Arcygenical
Anything can be done if you're willing to modify it.
You can easily flip the motherboard panel around... The hard part will be converting the PCI plates, which means you need to cut some aluminum/acrylic, to make it fit...
seb87
it's not enought remove the mb tray support and move on the other side ??
Arcygenical
Well, then the back PCI ports won't line up... And removing the PCI support plate means it won't fit into the case the correct way...
seb87
ops...you talking about this ?
Arcygenical
Nope, I don't mean that... Now, I MIGHT be mistaken, but I just don't think it's possible...
Too bad I'm out of TJ09's or I'd take a pic and show you in person.
I just don't think it'll fit geometrically. If you own the case, try mocking it up.
