Hello to all the [H]ard Community ! I've been reading this forum for quite a long time but now decided to share some thoughts and ask for advice
In December 2011 I decided to replace my black TJ07 with a silver one as I got bored of all-black PC. Since there is no place to get Silverstone products from in my country, I had to order the case from Germany. When the package arrived I checked the box from outside but did not open it right away as there wasn't any visible damage and I was too busy at the moment. When I finally got down to rebuilding my PC in June this year and took the new case out of its box the first thing I noticed was that the small door in front which covers USB, 1394 and audio jacks is quite wobbly... On close inspection I found out that all 4 screws used to secure the cover's frame from the inside of the case do not hold in place and can't be tightened due to broken or absent thread in corresponding mounting holes. To add more, 3 of 10 screws holding the top mesh fall out too and there is no way to put them back in, the surface of the U-profile is far from being perfect - just look at the photos - wtf is it just above the 5,25" slots ??? Side panels do not slide fully into place leaving huge gaps here and there between them and front of the case. And on top of that, it looks like the U-profile itself isn't stamped well - when I unscrew the bottom end of two back struts which hold the ends of the frame together on my black TJ07, the frame unbends a little and the struts go up BUT not sideways as on the last photo. Pics will tell more:
Is this all OK ? What do you think ?
