SilverStone TJ06 thoughts
NV-man
I just ordered a TJ06 to play around with, and I was wondering if anybody here owned one and what they thought of it. Thanks guys!
The TJ06 was (and sentimentally continues to be) one of my favorite cases.
I still think the front bezel is one of the best looking in PC-land.
With some modification it can be successfully watercooled and is a pretty fair platform for aircooling right out of the box. The "wind tunnel" is useless if you don't use a complimentary heatsink so be careful what you try to mount.
i got a black tj06. great case. although i cant make use of the wind tunnel. i cut spots for two 80mm fans behind the hdd cage and some holes in the motherboard panel for cable routing. some come with a hole behind the motherboard already but mine didnt. not sure whats teh difference and which revision is newer. either way its a great case.
How's the cooling without the wind tunnel? Does it really make that big a difference? Also Is this case cable management friendly?
well from the looks of it your PSU better have LONG cables
I have a PCP&C 510w sli, which has incredibly long cables... but with the unique layout of the case I was just wondering what cable managment would be like.
