Silverstone TJ-07 Casing
beckz
Anyone who has this casing.. is this casing noisy??
How much more noisy does it compare to a tj09???
It's horrible for noise isolation, SPCR gave it a horrible sound test review.
I have it and I can attest that it is like swiss cheese when it comes to dampening sound. TJ09 will be better with sound but the TJ07 is the flagship and very unique.
Oh ok..
I'm quite particular when it come to noise.
My computer run 24 x 7 and it's inside my room.. so noise is something i dun want...
How bad is that noise lvl???
I'm using the TJ09.. if i change to 07.. will the noise lvl increase by a lot?
I wanna change to 07 due to the space below for housing radiator..
I live in a small room, and after volt modding the stock fans that came with it I can sleep very well at night. The only thing I need to do is cover the bright LEDs for the power light. However I wouldn't call this a silent case at all.
mine is quiet, not dead silent, very low audible hum. thats with zalman 9700, which is the loudest part of the system by far.
I think i will keep my TJ09...
Just got a TJ07 sample today...
Bad frame work.. finishing not as good as the 09...
Worst of all the side panel r damn out of alignment..
